1 - 3 of 3 Posts
Looks good to me. It's a little deeper than the stock speaker but you should have room until it hits the back wall.
BuckFifty
If you use the HK amp it won't be able to handle 2 ohm sub. The amp is the weakest part of the HK sound system. I personally went with a bigger Rockford Fostgate amp and that made a big improvement. Bass is stronger and better with original subs and the mid & highs are crisper / cleaner with a mix of original mid driver in the front and new door tweeters.
1 - 3 of 3 Posts
