need further help
Thanks for the info on the wire connector for the level control.
I checked but the wire is firmly in place.
Problem is the mechanism that allows the low beam to dip down and tilt up again when the light is turned on seems to be restricted, and doesn't allow a full range of motion compared to the other headllight. I do see it move up and down slightly but most of time its stuck at low angle. I adjusted the beam upwards to be at same level as the other one, but then the beam later comes back up and ends up aiming too high.
Question: 1
Can I disconnect the control wire to disable vertical control so that it stay at same level?
Question2:
Any DIY tip to repair the malfunctioning level control mechanism? Replacing the whole assembly seems like a overkill.
Thanks in advance.
