I recently bought an X4 M40i with adaptive led headlight and every time i drive at night i need to press the auto headlight button near the BC button on the blinker switch. I was curious to see if there are ay codes out there where every time i drive the auto high-beams would be automatically on so i wouldn't need to press the button every time.
CARLY for BMW will let you code this feature. It works great. After this tweak, you can press the button on the steering wheel stalk, which then will turn off the auto headlight function until you either press it a second time or stop/start the car again. CARLY is highly recommended - lots of need features with almost zero risk of bricking your car.
If coded in FRM, then you never have to toggle HBA.
