1 - 3 of 3 Posts
i am having issues with my headlights like you turn them on they stay on for 5 mins and it goes off itself and either i have to play with the switches to bring it back on or if i let it be it comes back after a while.the fogs stay on if they are turned on and the high beams are kind a on and off as well.is there a relay which might cause this?please help.
Discussion Starter #3
got it all fixed up now.thanks all for your replies.just got another LKM from junk yard and replaced it everything is normal now.i also had a problem with the rear window defrost and found a blown fuse under the rear seat and replaced it and it is working as well.now the only thing left is the right rear door.still locked and can't get to it
1 - 3 of 3 Posts
