1 - 3 of 3 Posts
Hello do any of you know what model this sensor housing/tube come from :dunno:
E36 1996
M52B20TU
my brother came home today with heating problems. their are mounted a sort of housing at the top of the radiator tube ... betwen the rubber hose from radiator to waterpump .(that cracked) but this is not from this model for sure :confused: normally these sensors shuold be in the radiator. and sure enough their are a Bolt where that should be.... ever seen this ?
it was mounted where the metal tube is now on the second picture
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
I got no clue on the severely corroded housing, but that sensor looks like a combination coolant temperature/engine temperature sensor from an E30. Half feeds the ECU information on the coolant temperature for fuel/air ratio adjustment according to how hot/cold the engine is, and the other half drives the dashboard temperature gauge. The two do NOT interact.
Discussion Starter · #3 ·
so i found out that the housing is from a E39 when you after install a A/C compressor system :thumbup:
1 - 3 of 3 Posts
