Yep. Be really anal and have the dealer fix all your concerns, including door panel squeaks/creaks, worn door seals, wiper blades, steering shimmy, etc. And if you plan on keeping your car any longer, consider buying an extended 6yr/100K maintenance program ($1395 here: http://www.bimmerfest.com/forums/showthread.php?t=132955 ), which will take care of brake pads, rotors, drive belts, clutches, wiper blades, oil services, and inspections.frhsfootball80 said:better go in and start b/sing stuff and get alot of things done while ur under warranty thats what id do
