First of all, if you're going to do any serious work on your own car, I highly recommend buying a Bentley's manual. It details a lot of the regular maintenance stuff as well as some of the more obscure. Bentley's manual would have the information you're looking for.8psi318 said:
The best I can tell, is you will need to unbolt the door frame to get access to the window regulators. I can't recall off the top of my head, but the frame is held in by 6-7 bolts, which should be clearly visible once you have the door panel removed. Again, you may need to consult the Bentley's manual for this, but I believe the window regulator is held UP by these bolts, so once you remove the door frame the window regulator should be easy to remove.`
