Well, until I receive the dryer to evaporator hose I'm starting to find out more and more about the "pleasure of driving and especially owning a BMW":
- had to replace the wipers; I spent almost one hour using inserts (because previous owner glued the wipers to the arms, so i think i will need new arms + wipers)
- had to replace the OEM cup holders because I spilled hot coffee on my privates; (Private Ryan was saved!)
- Two days ago I went and fill up the gas tank; when reached almost full gas started pouring on the opposite side!?! after reading in the forum it looks like I have to take out rear seat and look for some locations where it happens. Meanwhile I enjoy a stinky gas ride until my tank will lower or I fix that thing;
- Last night rained, not very heavy, and this morning I found pools of water in the rear, both sides!?! after reading in the forum I found out that I need to reseal vapor barriers and remove the carpet...
Now, as I said, this is my first BMW and I like the ride, but I think quality build and maintenance is a PITA.
We own two Korean cars as well, one of them 14 years old and the other one 6 years old.
In 14 yrs other than tires, oil, brakes, bulbs and filters, once I forgot driver window open, rained and killed power doors - replaced under warranty, had to replace window motor driver side, this year crankshaft position sensor failed (DIY replaced $75), a hub bearing was noisy and clutch worn out - this was the most expensive repair and of course changing the timing belt twice was also expensive, but other than this AC/heater still works, cup holders are original, no water inside when raining, no gas spill, changing a wiper is done in 30 seconds flat, in other words everything works like 14 years ago and still very reliable! The other one had only one issue with a TPMS sensor, in 6 years (and it is driven by my wife)!
My beemer is 11 yrs old and has only 105k miles on it, the ride is nice and steady, engine seems to run fine and I enjoy driving it, but I can't stop asking myself/guessing what will happen to "my new baby" tomorrow or this weekend!?
Anyone?!?
