On my car under braking I noticed it would pull to the right. Upon inspecting the brake I found the right front brake pads worn a lot more then the drivers side. Odds are you have a caliper that is sticking. Rebuilt kits are available to fix it. Make sure you check the brake lines too to make sure their not obstructed as that can cause the same issue.
