RakNaks said:Okay lets start from the begining. What wheels and tire size do you have. What Michelin tire do you have. Were the rims checked out for run out...ie bent rims. Have you got a chance to strobe balance the car.... meaning on the car balanced? Have you changed the brake rotors on the car if you did what did you use.
I have had a similar problem, but mine is mostly with the steering wheel shaking at about 54 MPH, mostly when called. Two independent type BMW shops have checked out suspension, etc., both aligned the wheels and said "should be good to go", but the problem still occurs. Started about two weeks after getting new tires (Yokohomas). Have talked to both shops. They seem to minimize the problem. One said could be a brake caliper sticking, but seemed not too concerned. BTW, mine is a 740iL.84alfaman said:I need some advice. I've had a vibration that starts at about 40-45 miles an hour from the rear of the car. I feel it through the seat, not the steering wheel. At about 55, there is a small shake in the wheel. Also, the problem is always most noticeable when cold, and then it improves as the vehicle/tires? warm up.
I replaced the tires to BFG Traction TA's and the problem was still there. After several balances and a trip to the dealer, everyone still pointed at the tires as being the problem. So, I was able to get the tire shop to switch the BFG's for the OEM Michelin. I picked up the car today and the problem is still there!
My BMW dealer doesn't seem to know what else to do. They said my suspension checked out fine. Could they be missing something? This is getting frustrating!![]()
GuapOh said:common with e39's.
Fixes:
replace rear ball joints;
dynamic balance
enjoy.
BMW528i_Bilal said:Thanks for the suggestion Karri. My car is starting to vibrate again a little, i guess the tires were a temporary absence from the problem. I will certainally take your advice and ask the BMW service dealer to look in to the problem. I don't know about you but i think a German car needs everything replaced after 5 years of service. I just had a $4700 service done on the car, and once again its showing a problem again, will it ever stop????![]()
