Used the carsoft to pull some codes and need a little bit of help (or atleast guidance) on figuring them out.
System: DME/DDE
250 Tank Venting Valve: Function fault
System: Airbag
9 Ignition Circuit for right lateral side airbag
16 Belt switch, driver's side
The tank venting valve seams obvious as what to do but I just put in a brand new valve about 2 weeks ago. Any idea?
I have the complete carsoft printout with all the lines included but I'm really not sure what to look at. Is there a guide to figuring that out more accurately?
System: DME/DDE
System: Airbag
