1 - 2 of 2 Posts
Hey Guys,
My car needs abs module replacement because the old one behave very strangely and i bought used abs module from eb*y with exact same part number and now my module has arrived.
But i still quite confused with module coding or programming for that thing can fit into my car, I already had enet cable only ever used it for diagnostic never do a coding or progamming module.
anybody here can told me step by step how to code used abs module?
and which software should i use?
I really need ur help guys :cry:
2012 BMW F30 320i
Since you have an enet cable I'm assuming you have BMW standard tools installed on your computer(ISTA, etc.).
If this is true then you also have NCS Expert installed. Search around the internet for guides on how to use it and get familiar with it. It makes coding modules easy. There are a lot of tutorials online for coding a module to stock/default values. Here's one example, there are probably others that may or may not be as clear.
Using Expertmode to default code modules.
1 - 2 of 2 Posts
