1 - 5 of 5 Posts
I have a 2011 550i that takes very long to start and once it does there is hardly any power; however it does drive. The messages below pop up. I scanned the vehicle and got the following error codes. Any assistance is gladly welcomed.
Drivetrain
Drive moderately. Maximum drivetrain output not available. Have the system checked by your service center.
DSC malfunction
Chassis stabilization reduced. Drive moderately. Have the system checked by the nearest BMW Center.
Drivetrain malfunction!
Continued driving possible. Reduced acceleration. Have the system checked by the nearest BMW center.
Upon scanning the following error codes/messages came up.
120408 - Boost Pressure Control, Cut Off Pressure Rise Blocked
121002 - Charging Pressure Sensor, Electrical Short Circuit To Ground
121202 - Charging Pressure Sensor 2, Electrical Short Circuit To Ground
CD9304 - Bit Serial Data Interface, Signal Communication Fault
10A001 - Temperature Sensor Cooler Output, Electrical Short Circuit To Battery
160301 - Crankshaft Sensor Signal, Gap Error Tooth Time Implausible
12B104 - Lambda Probe Heating Before Catalytic Converter Activation Open Circuit.
Looks like some electrical short on the engine or around the DME is messing up the system. The fault is not necessarily related to the sensors listed.
Discussion Starter #3
Thanks alot. Was thinking the same thing. I have actually replaced the cranskshaft sensor as well as the 2 turbo cooler sensors. Still no luck.
Get an electrical diagram and start measuring the voltages on the misbehaving sensors, that could lead to the problem. I heard Ista Rheingold has the diagrams.
Discussion Starter #5
So I ran a scan again with an Innova Scanner to get more common generic codes to see if anyone has experienced any of the issues.
Here are the codes.
P0727 - Engine Speed Input Circuit No Signal
P0241 - Turbo/Super Charger Boost Sensor B Circuit Low
P0237 - Turbo/Super Charger Boost Sensor A Circuit Low
P0370 - Timing Reference High Resolution Signal A
P0030 - HO2S Heater Control Circuit (Bank 1, Sensor 1)
U1164 - Message Monitoring Engine Control Check Sum Error
Any help/info will be appreciated.
1 - 5 of 5 Posts
