As far as I know this is the control arm bushing issue...
check http://www.bimmerfest.com/forums/showthread.php?s=&threadid=4672 for some more info
is there only one dealer in TN...? take it somewhere else...it could be a million thingsSean said:no one can help? I find that very hard to believe. :bawling:
While the steering wheel is being turned to the left the noise is coming from the right side.Two things I can think of: 1. Left tie rod end is going bad.
2. Outer ball joint on left control arm.
