1 - 12 of 12 Posts
My 06 325CI E46 will not start. That's because there is no fuel pressure which I verified. I checked the fuse it's good. I checked the fuel pump relay and it is good. I also swaped it out for the horn relay and everything is the same. I have 12 volts going to the relay. When I check at the fuel pump I only have 4 volts. I don't get it! :mad: I also checked the level sensor and it only has 4 volts also. I do not know what else to check. If anyone has any ideas I could sure use some help.
catso
Battery issue or battery cables, connections, junction point? :dunno: I'd check these and clean them up and see what you get. If it's the original battery, you're due. Heat kills batteries.
Discussion Starter · #3 ·
Battery is new and cables are good. I have 12 volts to the relay I just don't know if there is something between the relay and the pump.
Supporter of Bimmer Lore
...I just don't know if there is something between the relay and the pump.
Yes, I believe it is called "a wire".
:p
Given the way the relay is wired (see pic), you could try measuring the resistance between its output terminal (in the socket, #87) and the corresponding terminal in the pump connector.
Either that, or the ground lead to the pump is bad. This may be the case; recall all the "my taillights are bad" threads, all caused by bad grounding, so this is a not-uncommon problem.
Living Life At The Beach
run a temporary wire from the relay to the pump. if it now works, you have a problem in your orig wire tht you have to track down, or bypass
So what happened? I know it's 4 years later but now I'm having the same problem. Only 5 volts to the fuel pump. I measured the voltage across the pins and it's just under 5 volts. I used a ground on the body and got the exact same voltage. I swapped out the relay with no change. Still <5V. I can't get to the back of where the relay plugs in to check the output voltage of the relay. How do I get behind there to check? I suspect the power wire has a bad spot but I can't run a bypass to check it until I can get behind the relay plug. I checked the voltage at the fuse and it's 12V. I'm pretty sure that the fuse comes after the relay, so I probably have a bad hot (12V) wire between the fuse panel and the fuel pump. Any confirmation? I'll try to run a bypass tomorrow and see what happens.
Any ideas would be appreciated.
+1 on ahull info
Sounds like you might have a bad fuel pump. Classic
Check your fuel pressure at the fuel rail. If weak, replace your pump.
I believe you're right. I just put 12V straight to the pump with NO JOY. Not a whir or a click. BAV Auto, here I come! I'll post if the new pump solves my problem.
Thank you!
Keeping it surreal
Thank you!
Also, for future reference, Check the OP`s join date, and post count. Like this thread....the guy made 5 posts 4 years ago, and was never heard from since....quite common.
1 - 12 of 12 Posts
