1 - 15 of 15 Posts
Just replaced eccentric camshaft sensor and put it all back together and now I am getting codes p0021 and p0024 does anyone have any advice on these codes
I guess you meant vct, not vtc?
Is it a hard fault or can it be deleted? Seems like you may have a Vanos timing issue, not sure how you could cause that by only replacing the eccentric shaft sensor. I'd check the Vanos timing to make sure it's 100%. But you'd need a few special tools for that.
Either that or the sensor wasn't installed properly but it's a straight forward install. Make sure all wiring you disconnected is reconnected.
Discussion Starter #5
Yes meant vct sorry didn't realize spelled wrong and I didn't mess with timing so don't think that would be the problem I am checking wires and everything I'll let u know how I make out thanks for reply
Discussion Starter #6
Checked all wires and everything was connected right and in right place when u hit the gas u can hear a sound of air sucking in almost sounds like is in air intake but there no leaks sounds like is in intake manifold
Discussion Starter #10
Checked them and they are good I cleared codes and started car again and now the p0021 and p0024 are gone And codes p0300 p0305 and p0308 are on
Discussion Starter #13
It's just throwing codes doesn't miss fire when running and yes connected all coils back right
Discussion Starter #14
And wasn't throwing them codes until unplugged and checked solenoid connectors after checked then and reset it started giving p0300 and others codes and not the codes was throwing before
That doesn't really make sense.
Usually will only throw those codes for misfires.
I'd swap cylinder 5 coil with 6.
Cylinder 8 with 7. Erase faults and see what faults come back.
If the faults change you got bad coils
1 - 15 of 15 Posts
