Hello,
New to me E34 1995 525i in beautiful condition. I am sorting through the shortfalls and the first item is the blower is inoperative at all settings. Not reading ahead I started the diagnosis with the basics and not looking for the blower motor or resistor issues I've become aware of since.
I started by checking the fuses and checking for power at the fuse terminal. Which there is non with the key on. So I am working back with the relay one step toward power in the schematic. The relay looks good and is the yellow one that seems to be for European models and not readily available. PN 61361390383 Can anyone confirm that this is the correct part number for my 1995? The RealOEM site does not show a listing that corresponds to the correct layout need for my car and the #13 choice is blanked out as not fitting my VIN. My VIN is: GK54550
I check power at the relay terminal block and have correct responses to 30(2) Power Ket Off, 86(8) Power Key on, 85(4) continuity to ground. I need to check for continuity from 87(6) to F19 but don't have a properly shunted DVOM at home and will check tomorrow at the shop.
Here's where it gets strange. The relay listed above has the spades located so the terminals fit into the wrong slots to make the relay function. The relay holder in the car has the number 2 slot which corresponds to always power toward the front of the car whereas the relay has the spade for that spot 90 degrees clockwise and all the other spades 90 degrees off.
My guess is someone was working on a blower problem and found the relay PN 61361390383 on a thread from a European site and bought and installed it. That there is another relay with the correct configuration that I need.
If anyone can check the number on their relay in the Front Power Distribution Box. It's the relay on top right as looking standing at left front fender looking at the box. Notice how the spades are laid out compared to your holder, please. The brass-looking receptacle is number 2 and always hot and should be 30 on the relay but the way my relay fits the #6 slot would be always hot.
