Hello all you fellow BMW owners out there!!!
I am new to this forum and so I am not sure whether im doing this right!!! I am Mark and I own a BMW 525iSE (2000) and I have a problem to solve !!!
I have had my car looked at by several people and on the face of it appears to be problem free. I have always looked after my car and of late it has developed a rather nasty power drain. I have had the battery replaced, and Halfords did a check on the battery and its fine, they also checked the alternator, its fine too. I took it to the entertainments place that fitted everything in it....and they found that the battery was fine and the alternator is charging at 14.85 volts and so thats fine too.
I was advised to buy a voltmeter and check the battery voltage every time she wont start as I understand a 0.5volt drop will make the engine management system kick in and say "NO im not starting" and so you just get a click click click, instead of trying to turn it over!
One one occassion it read 11.58 volts so should have started but never, on another it was 8.6 volts so wouldent start. We thought a sticky starter motor maybe but we are not sure.
I opened the boot today and checked the voltage again before starting her and it was 10.35 volts. So i knew it wouldent start and she never! as soon as I put the key in the ignition and turned to the first position, the battery voltage dropped at the rate of knots starting at 10.35...34...33....32...31.....30...29 ect one every second. took the key out of the ignition...it stopped.
Now to add to the problem, once she is started she will be ok all day and sometimes for several days before this happens again!!! It is really bugging me now and I am trying to think what to try next or how to eliminate faults.
Anyone who can help me on this problem I would really really appreciate it as its bugging me. I have a insulin dependant diabetic little boy aged 2 and in am emergancy I need reliability from my BMW!!! Please help me peeps! Kindest regards Mark :dunno:
