hopesbeemin325i said:
i just changed out my alternator and the car is doing wierd thing like the gear light comes on and the battery light is flickering and the check engine light comes on and off and the radio will just turn off. do i need to reset the computer in the car or is there something more going on that i just don't know. so anything that you can tell me would be great. thanks alot :dunno:
Hmm this sounds.. not good.
Get a voltmeter hooked up and see how it looks. Something with a needle will be best, but a digital one will work if you have to. Make sure it's putting out proper voltage, should be 13.6 or 13.8 if memory serves. Anywhere between 13-14 will be "ok."
Make sure the new Alternator is in fact capable of producing enough amperage for the car -- it should be rated equal or higher than whatever is stock. You didn't mention if it was just a straight replacement, or if you replaced it with something "else."
If you've got an "underdrive pully" on there, take it off and put the real pully back on.
Make sure the belt has proper tension. Too tight, and it's going to end up breaking. Too loose, and you'll learn soon enough -- having the headlights on or any appreciable electrical load will make a horrendous squeeling noise we've all heard at one time or another.
