Recently, my 2004 325i with 45,000 miles has lost power steering. One night I drove it with absolutely no problems. The next morning I moved it 3 blocks and the power steering was completely gone before i pulled into the parking spot. I proceeded to check my PS reservoir and it was a bit low (see pictures attached). The fluid was actually low enough to not be touching the dip stick. But there was fluid in the reservoir. I checked all of my lines for leaks as well as the boots of the rack and found no fluid. I proceeded to refill the reservoir to the appropriate level. Upon refilling the reservoir (it only took about 4 oz probably), the power steering is still non-functional. Is the issue probably the power steering pump? Would the level being low have caused a pump failure? I am a couple hundred miles away from my garage so I don't really have the necessary equipment to do the repair myself. If I bought some cheap driving ramps to raise the front end up, could I replace it on a street? What kind of labor costs am I looking at to fix the problem if I take it to an independent mechanic?
