Hi all,
This is my first post on bimmerfest, I've owned my 2002 E46 330D Sport for 4 years and have had almost no problems. In the last week though some dashboard lights have come on, I've had the fault codes read but neither myself nor the mechanic are any the wiser!
Both the DSC and parking brake lights are constantly yellow, and the system gives a warning chirp when you set off. The DSC is not working and although I haven't tested the ABS I'm pretty sure that's not working also.
The mechanic has flushed and replaced the brake fluid, checked and cleaned the ABS ECU and tried a new DSC sensor (apparently under the passenger seat). He has also checked and cleaned the contacts to the ABS ECU. None of this has made any difference to the fault.
I have a list of the fault codes which the ECU has logged, which are:
5E5D
5D99 DSC sensor CAN fault
5D8C DSC sensor CAN timeout
I've been told that it might be a wiring issue but I'm not sure this is the case, no work has been carried out on the car recently that could have caused it. I was told that the old brake fluid was quite contaminated, not sure whether this is related or not.
Any info would be welcomed, at the moment I'm considering taking it to the stealership but at over £100 per hour it's not going to take long for the repair to cost more than the car is worth!
Thanks in advance
G
5E5D
Thanks in advance
G
