Help reading INPA lambda probe system test
4.4K views 3 replies 3 participants last post by  M_Bimmer
#1 ·
Hello all,
I've have been trying to diagnose an issue on my E46 that seems to be air flow related. Everything in INPA is within range, apart from one reading relating to lambda probes in both banks, before and after cat. All four are far above normal values as can be seen in the attached image. Would anybody be able to explain what the readings represent and any possible causes? Thank you.
1027748
