Anyone have experience removing the motor that raises and lowers the top (not the one that raises and lowers the boot cover. I have it loose except for the "S" hook that is attached to the top of the motor with an allen bolt. Can get the motor out without detaching the large stamped metal part that pushes and pull the back portion of the top.
If you have messed with one these I hope my poor description is adequate to explain my problem. The manual I have has pathetic instructions that I can summarize as "remove bolts and disconnect modular plugs."
Any help would be greatly appreciated.
Mark
Mark
