Hey if anyone can help I would greatly appreciate it. My 03 325i recently overheated. I opened the engine to find that the main cooling fan was completly destroyed. After taking everything out I found that the bearings were shot in the water pump that I had replaced last November and the play in it caused the fan to hit the engine. So new water pump, new fan housing, new fan clutch, new fan and a new radiator. All was well except for everytime that I started it, it would die immediatly, it took 3-5 times of starting for it to stay running. It had sat for almost 2 months before I got the cooling system fixed, so I just assumed that it was some old fuel. Well a week of driving and about 300 miles and I started it up, and it had a constant uneasy idle. When I tried to put it into gear it would die. It kept jumping between 300 and 750rpms, almost dying everytime. It stayed like this for 10 minutes. I checked the oil, when I pulled the dipstick out, the uneasy idle stopped, but when I put it into gear it would still die. I had cleared the error codes because I had an O2 sensor code on for the last 6,000 miles, and during that week of driving I got, error codes P1085, P0174, P0171, and P1351. I have ordered new plugs, a new fuel filter, and while I am at it, air filter and new oil and oil filter. So in 2 days I will get all of these things into the car. My qeustion is, do you think that this will fix it, and also while I am working on it, I have an oil leak somewhere on the driver side behind the alternator, it leaks about a quart every 4,000 miles (Picture below). I have 106K, so should I try and fix the oil leak, any input would be greatly appreciated. Thanks.
Also side note, I have had to add about 3 liters of water and coolant to it since I put it all back together. No coolant in the oil and there are no visible signs of coolant leaking. And the resovior was replaced last year and both thermostats, so.....
