am i screwed if the part that the valve cover cap nut bolts onto snapped off? how do i fix this??
Thanks for your help. Do you know the size of the bolt? I need to pick one up before I rip open the engine.no go to the local auto parts store and get a replacement bolt. i had the same thing happen to me. i got a bolt and a couple of washers. looking at the motor, i took out the stud/nut, at the top of the head, next to the rad. put that part where i snapped the other stud, and put the replacement bolt in the place where it took the other off.
I had a leak & replaced the gaskets many months ago. However, I'm still getting misfire codes & a little bit of oil seepage into the spark plug wells. I was going to replace the plugs yesterday but figured I would torque the cap nuts to spec instead, in case that was the culprit. I overtightened one of the cap nuts & it broke off along with the piece that goes into it from the engine.Wow, sure nough, you had a little leak in there huh? How does that part break off? Were you just removing the cap nut and it busted off with it? Curious if you painted or powder coated your VC's while they were off.
I hope for your sake whoever changed them last didn't forget to put a little anti-seize on them.I wasn't able to remove the plugs either. I think they've been in there for a while & didn't want to force them anymore than I was because another problem is the last thing I need at this point.
can't remeber what size but i took out the broke stud, and took both peices with me, showed it to the guy at the parts counter, and said i need one this long with the same threads. i think it was a 10mm head size.I had a leak & replaced the gaskets many months ago. However, I'm still getting misfire codes & a little bit of oil seepage into the spark plug wells. I was going to replace the plugs yesterday but figured I would torque the cap nuts to spec instead, in case that was the culprit. I overtightened one of the cap nuts & it broke off along with the piece that goes into it from the engine.
thanks for the info!!can't remeber what size but i took out the broke stud, and took both peices with me, showed it to the guy at the parts counter, and said i need one this long with the same threads. i think it was a 10mm head size.
My dealer didn't have the stud but they told me it's probably a M6 x 30 so I went to Home Depot & picked up a screw & cut off the head with a hack saw. It fit perfectly (thank god).it will be ok to spray pb. any of it that gets in there will burn off. just be carefull gettin those out. i know a freind once broke a plug off.
Those are the only codes that I've been getting. The CEL comes on during brisk acceleration (& WOT) from 4k rpm on up & blinks. The car is not smooth & shakes until you turn it off. When you turn it back on, the shakes are gone but the CEL is solid.are you getting any other codes? I had similar problems and it turned out to be frayed o2 sensor wires.
good luck!
I think the misfires are caused by the oil pooling around & mucking up the plugs. This can damage the cats if left unchecked for a long time. I've heard that the coils are rarely the problem - if anything, it's the boots. The plugs are NGK BKR6EQUP, which many e39 enthusiasts use w/o problems.I'm not sure that the misfire would be caused by cats. I suspect your coils may need to be replaced. What spark plugs did you use?
