1 - 5 of 5 Posts
Does anyone have a torque spec on this banjo bolt?
Font Line Automotive exterior Auto part Parallel
I'm either over-torqued, under-torqued or I damaged my new washers during install because I have the teeniest drop showing up after hours and hours of sitting.
Nuclear engineer
02/2012 X5 35d M57Y CPO 116K miles NOKIAN WR G3 30K miles
pump and steering gear/banjo bolts, steering hydraulics
E38Banjo bolt M12Replace sealing rings33 Nm
E36, E39, E46, E52Banjo bolt M14Replace sealing rings35 Nm
E38Banjo bolt M14Replace sealing rings39 Nm
E60, E61, E63, E64M14 non-return valveReplace sealing rings35 Nm
E53, E60, E61, E63, E64, E65, E66, E85 / S54, E86 / S54Banjo bolt M14Replace sealing rings33 Nm
E36, E38, E39, E46, E52, E53Banjo bolt M16Replace sealing rings40 Nm
E60, E61, E63, E64, E65, E66, E83, E85 / S54, E86 / S54Banjo bolt M16Replace sealing rings35 Nm
E38, E53Banjo bolt M18Replace sealing rings45 Nm
E36, E38, E39, E46, E53, E60, E61, E63, E64, E83Cap screwReplace sealing ring36 Nm
E65, E66, E67Cap screwReplace sealing ring39 Nm
  • Like
Reactions: Markst and ede39
Discussion Starter · #3 ·
Thx!
Nuclear engineer
Joints with elastomer seals like O-rings should not be dependent on make up torque but rather smooth support against internal pressure.
Discussion Starter · #5 ·
Still weeping...not as bad (don't think the drop has hit the floor) but better. I think I deformed the washer when I first installed it (grit vs overtorque). New parts and repeat but 33Nm felt a lot better than what I originally used. Luckily the system takes ATF and not CHF.
1 - 5 of 5 Posts
