Preface: Dinantronics Stage 1 is installed, I've contacted Dinan as well, waiting for a response.
Car is in limp mode this morning. Nothing out of the ordinary happened in terms of driving, was just dropping my kid at school. One strange thing that happened was, when exiting the parking lot at his school, the parking sensor came on, but maybe that's because the person behind me was too close? The car went into limp mode shortly after this though, it was strangely coincidental. I checked all the connectors and bolts involved with the chip, charge pipe, and intake for looseness, didn't find anything obvious.
Here are the codes:
Boost pressure operating range: Pressure too low
Code: 121531
0x120408 charge pressure control: shutdown due to reaction
Code: 120408
Boost pressure sensor, electrical: Short circuit to ground
Code: 121002
Boost pressure - atmospheric pressure, comparison, boost pressure is too low
Code: 121533
My understanding is that the first two are general faults and don't point to any cause (reading this: https://www.bimmerfest.com/forums/attachment.php?attachmentid=494785&d=1425058449)
I *do* have a boost tap installed, certainly I could try removing that, but I have reservations. A couple of weeks go I got a code for a faulty hose (20E120). I checked the car over, found nothing wrong, cleared the code, and it never came back. Is this a normal BMW "thing"? I remember reading somewhere these engines are super sensitive...whatever that means.
TIA.
Here are the codes:
Code: 121531
Code: 120408
Code: 121002
Code: 121533
TIA.
