I got a rock chip on my hood and attempted to touch it up myself. It isn't looking all that good right now.
I tried wet sanding the mound of touchup paint with 1000 grit sandpaper but scratched up a little of the area around the original rock chip (I am assuming I just scratched the clear coat?).
What should I do about the scratch from the 1000 grit paper? I tried to hide it with Meguiar's Scratch X and 3M IHG. It's a little better but you can still see it from certain angles. Do I need to buy some 2000 grit paper and wet-sand out the 1000 grit scratches, then re-wash and apply polish/wax again? I am just scared to start sanding away with the 2000 grit paper because I don't want to make the scratches worse.
On a related note, if I have other scratches on my clear coat, is 2000 grit wet-sanding the answer? Again, Scratch-X helped but didn't get rid of the scratches completely.
Thanks for your help. Just don't know what to do at this point.
