1 - 6 of 6 Posts
Try this:
1. Not sure whether the key needs to be in acc. or start position, or this is even necessary.
2. Apply foot brake.
3. Lower both windows a few inches
4. Open top levers on both sides.
5. Lift the top manually a few inches.
6. Close top levers (just so they don't stick out).
7. Push button, and the top should drop to its resting point.
Warning - Thin Air
Is it possible someone has modified your car? Normally you need to apply the break as a way to keep someone from putting the top down at speed, but some people like to change things, so maybe someone disabled this feature on your car.
Discussion Starter · #6 ·
Lowering z3 softtop
Thanks for all the replies.my roof goes down to the point where it needs to
Bend.then it just locks.if I disconnect the electric motor it lowers all the way.but I need to bend the last section by hand.what does the small micro switch do ?
1 - 6 of 6 Posts
