yes i have a 328i need some help i have coolant in my oil but here what happen it was running fine changed out the coolant lines all of them even the ones under the intake changed the stater the water pump and thermostat and even a new battery changed the oil and it was good no coolant in it changed the coolant have not tried to start it yet so that is where i am baffled it was ok when i started on it so is there any way that coolant can leak down into the oil besides head gasket or bad head maybe i hooked something up wrong help
