Background: I upgraded my 01 530i with low cluster and low MID to a high cluster and a high MID. I created my own wiring harness using RealOEM and a BMW wiring diagram. After installing the cluster and MID, I used NCS Expert to code the LCM and IKE modules to accept the high cluster and MID, respectively.
The problems: 1. The MID does not display any high OBC functions when the BC button is pushed, 2. The high cluster does not display any high OBC functions when the stalk BC button is pushed, 3. the "PROG" function does not display when the stalk BC button is held down.
Observations: the stalk BC button will cycle through all of the 4 original low OBC functions; the check control appears to work flawlessly; when set to do an hourly gong, the time will display on the readout of the high OBC.
I've scoured pretty much every forum post covering this topic, but have yet to find an issue on point. Any help is greatly appreciated!
