1 - 10 of 10 Posts
Discussion Starter #3
51337435817
51337435818
These are the part numbers for the door's tweeters
You can see the reference of the center speaker in the third pic.
This mod makes a lot of difference in terms of quality and volume of sound
Do you have the HiFi version, not the stereo right?
In my stereo version there's no Central speaker and i'm planning to add one and to replace standard woofers and tweeters
Inviato dal mio Power utilizzando Tapatalk
Discussion Starter #6
Yes. It's the hifi version
Hi pllorenzo to open the door where are located the screws? I've seen there are some under the handle, there are others?
Thank you very very much for your post, without your post I almost messed up the trim of my X1 2016 , because in all the you tube panel removal process, you have to pry the trim above the door handle. With your pictures everything went smoothly. Thanks again. Now I don't want to get out of the car because of the sound of music that is so different from the base speakers. Also thanks to Bavsound.
1 - 10 of 10 Posts
