So the horn has been acting up. Ocassionally it will work and then stop working. And then work again. I've yet to check out the connections. Fuses check out. When the horn is not working, I will hear *clicks*.....
Any suggestions on whether you think it's the horn on its way out, clock spring or something else ?
If it was the horn, I would think it either is not working or it works. Not sporadic.
