Hotchkis Sport Sway Bar Set for 01-05 BMW M3 E46
Front & Rear
Asking $300.00
Enhance the cornering performance of your M3 with a set of H-Sport sport sway bars. Hotchkis M3 sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the M3 handling characteristics are excessive understeer and limited roll control. Hotchkis H-Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded understeer is eliminated and the handling becomes comfortably neutral. H-Sport sway bars feature a durable powder coat finish, greaseable bushings, performance rear end links, and 6 different tuning rates via multiple end link positioning.
1 3/16" (30mm) Tubular Front Bar 3 Way Adjustable. Rate Increase vs. Stock +11%, +28%, +49%.
1" (25mm) Tubular Rear Bar 2 Way Adjustable. Rate Increase vs. Stock +79%, +105%.
May not Fit Convertibles
P/N: 22826
MSRP: $560.05
Install Instructions:
http://www.hotchkis.net/_uploaded_files/22826instructions1365180540file.pdf
