Boing: to my knowledge ALC can be retrofitted to any year, but you need the proper headlight assembly as well as the ALC unit.
The left and right motion is a function of having ALC (adaptive headlight control); the ALC unit is a little box on the side of the headlight assembly (the box on the bottom of the headlight assembly is just the ballast/control unit, and all xenons have that). Also, all xenon setups have load-leveling for the headlights, identifed by the vertical motion you see when you turn the car on (this is controlled by the motor behind the door at the back of the headlight that has three screws (I think three).
If you look at my headlights you can tell that I do not have ALC because I have the regular H7 daytime running lights, whereas the 745's/760's with adaptive headlight control have lenses in the daytime running lights' places that look just like the low-beam lens (I think Sunny had a 760 with ALC).
This all may have already been known, but I figured I'd restate it anyway in case someone does a search.
