1 - 20 of 39 Posts
Hello I have F30 with replaced CIC. VIN is same in CIC like car, but navigation section is grey. How to enable navigation with E-sys? I read out:
E-Sys => Comfort Mode => FSC => Select "Check FSC Status" and get:
--> Read the state from "2" ECU(s) <--
EPS[DiagAddress=48(0x30)]
WBAXXXXXXXXXXXXX (My VIN here)
RootCertStatus not available
SWSigStatus accepted
SWTApplications
AppID 131(0x83)
UpgradeIndex 1(0x01)
SWTType SWTclassic light
FSCStatus accepted
FSCCertStatus not available
HU_CIC[DiagAddress=99(0x63)]
WBA3B3C53DF535145
RootCertStatus accepted
SWTApplications
AppID 23(0x17)
SWTType SWTclassic full
FSCStatus rejected
FSCCertStatus accepted
AppID 25(0x19)
FSCStatus rejected
AppID 27(0x1B)
FSCStatus rejected
AppID 111(0x6F)
FSCStatus rejected
AppID 156(0x9C)
FSCStatus rejected
AppID 155(0x9B)
FSCStatus not available
AppID 45(0x2D)
UpgradeIndex 5(0x05)
SWTType SWTshort
FSCStatus rejected
As far as I understand I should make AppID 27(0x1B) enable, as this address is for navigation Enabler, but how do I do it? Please shed a light, thank You!
Premium Member
I replied to your same PM.
FSCStatus rejected
Hello,
I have the same problem like the guy bevor,
My CAR is an e91 3,0xd ( original without an navi ) i have change the Radio in an nbt from x6 ( 06/2014 )
And i can't klick on the Navigation,
On esys stay " FSCStatus rejected "
Can you help me to ?
Regards Jörg
Premium Member
Hello,
Regards Jörg
And do you have an Emulator / Activation Module connected to your NBT?
Premium Member
FSCStatus rejected
FSCcertStatus accepted
AppID 222(0xDe)
UpgradeIndex 1(0x1)
FSCStatus rejected
AppID 159(0x9f)
UpgradeIndex 1(0x1)
FSCStatus rejected
The Rest i don't see at this Time, but i must work sorry
But i now that the other id's
Not rejected, the other id's are mit available
Like AppID 111(06x6F)
Premium Member
FSCStatus rejected
AppID 222(0xDe)
UpgradeIndex 1(0x1)
FSCStatus rejected
AppID 159(0x9f)
UpgradeIndex 1(0x1)
FSCStatus rejected
What is the first AppID? You cut it off.
6F is Sat Radio. ARe you in North America?
An guy from Mini has say
"You need to reload all fsc codes in NBT"
Is this right?
How i can do this ?
already not only what to do when old go?
Premium Member
Ist in the other pickture
App id 158(0x9E)
Is this right?
How i can do this ?
Sorry no i come from germany
My Brother bring it from canada to me
For Navigation only, you need A0, DE, and A9 FSC Codes Accepted. Your DE is Rejected, and you have not provided status for A0 nor A9, but I assume they are Rejected as well.
Either Emulator is Bad, or you wrote new VIN to NBT, and now NBT VIN and the FSC Codes inside it are mismatched. So is NBT VIN still the original Donor VIN?
No, the adapter I had before that was too old.
If I'm nbt the adapter to a completely new which was delivered 2 months ago everything goes
the seller of consumeretrofit it has just bestätitg, I would like to play a rauscopieren and new fsc
I will use the programs esys and tool 32 it took me 1 year to encode the nbt
do you have a link for me please where I can be well-read?
Thanks vor help
Premium Member
Thanks vor help
In lieu of writing Donor VIN back to NBT, you can go through the trouble of Importing and Activating a new set of FSC Codes, but this accomplishes the same exact thing, which is to sync NBT VIN and FSC Codes VIN, but it is much more work, so it makes no sense.
And if you do this, 1) You need set of original FSC Codes, and FSC Code Creation Date must be newer than the creation date of the current FSC Codes, else you will have to virginize NBT before you can Import and Activate them.
Premium Member
OK will try it thank you very much
When I had gotten the nbt was new been flashed, it may be related also to?
It is possible if flashed with wrong FA VIN.
I've played a's secured and new fsc.
It's still no navigation
I found a f31
Here I that fsc have backed it up.
I can change but not the vin.
How to encode leg nbt of the VIN number
Please help again
Thanks Jörg
Premium Member
I found a f31
Please help again
Thanks Jörg
Sorry, but I really do not understand what you ask.
the vin is the problem.
I have now fsc's by the f31
They fsc's can I play only the vin I can not change.
can you please tell me how
1 - 20 of 39 Posts
