21 - 39 of 39 Posts
Premium Member
the vin is the problem.
I have now fsc's by the f31
They fsc's can I play only the vin I can not change.
can you please tell me how
OPTION 1) Import FSC Code, and VIN will chnage to match FSC Code VIN.
OPTION 2) Use E-Sys FSC Extended => WriteDataByIdentifierVIN.
I got a 7E FSC code for my cars VIn and dont know how to import can you please give me a detailed instruction on how to do it using esys.
Premium Member
thanks shawsheridan i will give it a shot!
Sorry
Hier we have written bevor
I have Save the FSC's and and After the reinstall i can read
FSCStatus cancelled?
Can you help over teamviewer?
Is this possible?
Premium Member
Sorry
Is this possible?
Cancelled means VIN mismatch between NBT and FSC Codes, or they match and your Emulator is not working.
Hi all
I have the same problem here - with wrong VIN in NBT after Flash.
I have the org. FSC's from BMW Dealer - but where do I check the VIN of the NBT ?
I've heard - that you can delete the FSC from the NBT with Tool32 / NBT.PRG.
But how to viginise the NBT ?
PM are accepted :thumbup:
Premium Member
Hi all
You don't need to Virginize NBT. Just write correct VIN to NBT.
Use E-Sys => Comfort Mode => FSC => Check FSC Status to read current NBT VIN
Use E-Sys => Editors & Viewers => FSC-Editor => FGN kurz to read VIN from FSC Code
Use E-Sys => Expert Mode => FSC-Extended => WriteDataByIdentifierVIN to write VIN to NBT
Hi
Tried - abut still error.
I've cleared the FSC with Tool32 / NBT.PRG and '_STEUERN_DELETE_PERSISTENCY_INTEL_PLUS_SWT'.
Then the FSC's should be gone OK
The VIN is the right in both Certificate and NBT - but still I get the Error:
FGN_CHECK_FAILURE; ECU: HU_NBT_63_ETHERNET
Must say - that I run without and Emulator,- but get the error even though if NBT is not connected to my test rig?
Can you see what goes wrong :dunno:
Premium Member
...Can you see what goes wrong :dunno:
Sorry, but I can't tell from the pictures. I have no idea what you have going on there.
How do I create a complete copy of the nbt?
I have a f31 and should use this.
Here are all complete with certificate Yes all fsc original only as secure.
because to me it looks almost same as shown on the pictures
Premium Member
PM me the short VIN of the car itself, and both the current NBT FSC Set and the F31 NBT FSC Set.
Clearifling:
- First I delete the stored FSC codes in NBT with Tool32
- Then I check status on FSC's
- Then I tried to update them - write & enable
- But no succes
Anyone that can help with this?
Guess it could one of those areas where people don't wan't to share their knowledge.
PM is also possible :thumbup:
Clearifling:
- But no succes
Did you ever find a solution for this?
Hello. I'm going to use this thread to explain my problem. I had a head unit entrynav (2015). And now I have retrofitted an nbt head unit (it's from 2015 too). I have written the vin of the car in the head unit with the esys option ''writedatabyidentifiervin''. I have put the code 609 in the FA, and I have done 'code' in the head unit.
The navigation option is greyed out. So I got a set of non-oem fsc codes with the vin of my car. Also the file FSCS.der - SIGS.der. And the .bin to patch the head unit.
I put the bin on a flash drive, wait 30-40 seconds, and manually reboot the head unit. After a minute or so, the head unit restarted automatically. So I think the patch is well applied.
Now in esys, in settings, in the fsc tab, attach the file fscs.der
In the fsc extended tab, I did 'storesigcert' and attached the sigs.der.
And now comes the problem. If I do store fsc, the fsc says 'ok' and if I do a 'check fsc status', the result is loaded. But if I do store fsc + check fsc instead, the result is 'fsc rejected' and 'fgn_check_failure'.
I put all the fsc on loaded, I closed the car and wait 30min, but the fsc still did not activate. When I got back home I checked the status of the fscs again, and they were like 'fsc rejected'.
Any help is appreciated. The fsc were obtained with the hu tool 2.6 program. Thank you.
-> Read the state from "1" ECU(s) <--
HU_NBT[DiagAddress=99(0x63)]
WBA1H31040V313422 <-------------------------THIS IS MI VIN
RootCertStatus accepted
SWSigStatus accepted
SWTApplications
AppID 158(0x9E)
UpgradeIndex 1(0x01)
SWTType SWTclassic full
FSCStatus loaded
FSCCertStatus accepted
AppID 160(0xA0)
FSCStatus loaded
AppID 222(0xDE)
FSCStatus loaded
AppID 111(0x6F)
FSCStatus loaded
AppID 159(0x9F)
FSCStatus loaded
AppID 156(0x9C)
FSCStatus loaded
AppID 229(0xE5)
FSCStatus loaded
AppID 169(0xA9)
UpgradeIndex 7(0x07)
SWTType SWTshort
FSCStatus rejected
FSCCertStatus not available
MsgText>job failed with negative response error:
code: RoutineControl returned negative response
description: service Routine Control Verify FSC returned positive response with with result status = FGN_CHECK_FAILURE; LinkName: HU_NBT_63_ETHERNET
severity: ERROR
</MsgText>
Rectangle Font Screenshot Software Operating system
Rectangle Font Technology Number Screenshot
Rectangle Screenshot Font Operating system Parallel
Premium Member
21 - 39 of 39 Posts
