1 - 7 of 7 Posts
My wife got some cement spots on the hood while passing cement guy, who decided to wash his dirt onto upcoming traffic. :mad:
It was few big spots at the beginning, then I quickly washed it (should did it better! :(), but in a few days I've discovered a lot of small splashes all over the hood. And now it's much more difficult to get them off.. I've removed 90% of that cement, but remaining 10% doesn't want to go..
I washed the car using Turtle ZipWax car wash, then rubbed spots with wet clean sponge with quite heavy pressure.
Anyone could suggest what to use and how?
If you don't regularly detail your own car, have experience with claying the car and have used a wide range of products and processes, I'd try and find a good detailer to take a look and give you an opinion/quote.
As much as I would love to do many of these things myself, I don't always have the time, so there's always someone better suited for a job like this when it comes up.
The professional route is probably the best.
Haven't used but check this:
http://topoftheline.com/cement-concrete-remover-auto.html
Reading the sugar reference you might try a bit of Coca Cola in an obscure spot.
Southern legend has it that Coke is good to strip road film off your windshield!
I know Muriatic acid is used to remove residue, not on cars thought. But I'd try WD-40, just spray liberally and wait a few, then with a rag hopefully it'll come off. Just look for anything that can break down cement without damaging the soft car panels or the paint.
If not planning a respray.
Leave the acid alone!
Soaking in wd might work.
The Driver
1 - 7 of 7 Posts
