Ok, I spent ages searching through forums to figure this out. It seems everyone has the same issue, but there are really no solutions... until now!
If you can hear your pump working, but no water comes out of the nozzles, this is the easiest fix. But first, let me bask in my own sense of self accomplishment for a moment........ ahhhhhh. Now, here we go:
1. Dont bother taking out the pump, because if you can hear it working, then it works. The filter is just blocked with mould and algae. (If you cant hear the pump, then you need to take the tyre off, take off the wheel lining, pull the bottle out and replace the pump).
2. If you can hear he pump, unscrew the filter near the nozzels. Then, unplug the first nozzle and push it into a garden hose. This will allow water to run through the hose and onto the ground.
3. Next, pour household bleach down the washer pipe. About a half cup to start with. Then fill it with boiling hot water. This is why you need the hose - to stop bleach going over your engine and car.
4. Start using your washers via the stalk. It may take a while for the algae to break down. After about 10-20mins, water will start coming out through the hose. If some goes onto the car pour a heap of water over it.
5. Once the water is low, refill the washer inlet with bleach and hot water and keep using the stalk to work the washer.
After about 20-30 mins, your nozzels will be clean again. Easy fix.
Let some of the bleach/water mix sit overnight to kill the rest of the algae.
