1 - 20 of 40 Posts
My car is dead and I want it to go into neutral. Does it have a shift lock and if it does. How do I get to it?
P.S. It's automatic :( and I want the car moved out of my garage. My battery's dead. I can't buy a battery right now.
Fireballs inc.
is it autotragic?
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
Replace the battery with a charged one, put the key in the ignition as if to start the car, turn to the on position, shift it into neutral. You _may_ have to put your foot on the brake while doing this. I can't recall if there's a brake interlock or not.
Why do you want it in neutral? DO NOT tow it.
Fireballs inc.
you need the brake pressed
Discussion Starter · #5 ·
someone please reply
Discussion Starter · #8 ·
yeah I got it open though something actually jammed it down
It must have been the supercharger that killed the car, you may need to have another custom battery installed in the trunk compartment :dunno:
D'oh, You Kids!
What part of my response did you not understand? I didn't tell you to BUY a battery. You can borrow one long enough to shift the car into neutral. Sheesh.
Some people just can't be helped.
Fireballs inc.
+1 hornhospital really did answer your question....
Discussion Starter · #15 ·
The ignition is out so I can't crank it. That's why your idea doesn't work. I would have done that if my ignition worked.
You don't have to crank it to be able to shift it into neutral :confused:
Are you saying you have removed the ignition switch ? You can jump the harness with a test light and shift it, after you borrow a battery to power the car :dunno:
D'oh, You Kids!
Skillet77, I never told you to crank the car. I said turn the key to the first ('run') position. The energizes the shifter lockout solonoid, releasing the shifter lock (with the brake depressed...thanks Hater433:thumbup:).
Oi! :facepalm:
1 - 20 of 40 Posts
