1 - 3 of 3 Posts
Hey guys,
My car is Mini cooper R56 N16 2013 base hatchback. After reviewing this link below to follow instruction to change engine oil, this confused me because its not showing the same car. My car has the engine filter on top, not from the bottom as in the link diagram below. Please confirm my specification questions below.
https://www.newtis.info/tisv2/a/en/f56-cooper-hat/repair-manuals/11-engine/11-13-oil-sump/1VnXlvMfL9
My questions are: I've also supply links to support my finding.
What is the Filter cap hex head size?
What is the Filter cap torque spec: 25nm?
https://www.newtis.info/tisv2/a/en/f56-cooper-hat/repair-manuals/11-engine/11-13-oil-sump/KwHahuSZ
What is the Drain plug torque Specs: 25nm?
https://www.newtis.info/tisv2/a/en/f56-cooper-hat/repair-manuals/11-engine/11-13-oil-sump/KwJgvKAe
What is the filling capacity? 4.25L?
https://www.newtis.info/tisv2/a/en/f56-cooper-hat/repair-manuals/11-engine/11-13-oil-sump/1VnXnWb2mz
Thanks guys,
I***8217;m sure you***8217;ve changed the oil since the OP. But, for next time:
Oil capacity: 4.4qt
Filter Cap Hex size:27mm
Oil Drain Plug: 22 ft-lb
Oil Filter Housing: 18.5 ft-lb
1 - 3 of 3 Posts
