1 - 2 of 2 Posts
Hello, I have a 2008 e93 and soon will be needing to replace the battery since a yellow battery light is coming up after starting the car.
I have read that the programming of a new battery can be done with NCS Expert which I have installed.
Is there a documentation or someone have the steps on how to program the battery?
Thanks in advance.
Hi, if you replace the battery the new battery needs to be registered in the car.
You can register the battery with either ISTA or tool32. If you change the battery size or the battery type you have code the change with NCSexpert or ISTA-P
1 - 2 of 2 Posts
