DoruWhen i remove the dipstick to check the oil level, it's very hard to pull out. Clean it, re-insert to accurately measure the oil level, comes out easy. this is clockwork. So, the vacuum is pretty strong?
Another weird thing:
Before changing the CCV (& new style dipstick) to the winterized version I always knew exactly my oil level.
With the new dipstick, it's very iffy.
... stuff deleted ...
That CCV system and whoever designed it should be shot
I have the new, cold weather guidetube too & have found oil level measurements to be consistent. Perhaps the retaining brace and bolt for the tube on your engine is a little loose. If the guidetube can move up & down even slightly, the dipstick reading will be thrown off. The span from lower to upper mark on the dipstick is only 16mm or 5/8" so it wouldn't take much movement in the guidetube to make a difference between a reading of full and down half a quart/litre. I can't think of another reason for the inconsistent results you are seeing.
BTW, my dipstick is sticky too. It was on the old concentric tube design & still is with the new cold weather version. But it isn't vacuum. A properly functioning CCV will hold crankcase vacuum at 4 - 6" w.c. which converts to ~0.25 psi. Guide tube diameter is ~1/2" for an area of 0.2 sq. in. So the force exerted by the vacuum is ~0.05 lb or ~3/4 ounce. Besides, once the engine stops crankcase vacuum bleeds away in seconds; long before I'm under the hood yanking on the dipstick. The stickiness must be caused by the O-rings adhering to the guidetube.
I do agree with you the BMW's CCV compares badly with the PCV I'm used to with its $15 cost & 5 minutes to change. It calls to mind advice a mentor gave me years ago: "there comes a time in every project when you have to shoot the engineers and get on with it." I think BMW missed that checkpoint on this engine.
