1) You can use any version of E-Sys. You do not need a Patch or Token for VO Coding, only FDL Coding.How to VO Coding?
1. What I need? I have e-sys 3.22.5 (payed version) & 49.0
can make change vo with esys?
2. If VO coded... Can revert to Original VO?
Thanks...
Is there anywhere all this is explained i.e. what does and does not require a patch/token? what is FDL?1) You can use any version of E-Sys. You do not need a Patch or Token for VO Coding, only FDL Coding.
Save FA first, then you can Edit it.After I do Vehicle Order: Read, the Edit button is greyed out so I cannot edit. What am I doing wrong? Trying to VO code the ASS & seatbelt reminders off.
E-Sys 3.24.3
v.55.1_PSdZData_Lite
I-Step: F010-15-03-502
Thanks.
That did it. Thanks.Save FA first, then you can Edit it.
Same. E-Sys PSdZData is ripped from ISTA.I got a question on the e-sys program. I see that it also use psdzdata lite and full version. Can I use the psdzdata full version from ISTA on e-sys program? Are they the same ?
You are supposed to use FA read from car, not FA Sample.Hi Shawn
I think I screwed up something using the E-sys software. Do you have the FA file for 2011 F10 535i?
I got the Chassis Stabilization Malfunction error every time when I start the car, I can't switch to sport , sport +mode. Then last night when I tried using this e-sys program, I went to DSC (screen shot) and using the FA file that came with the program it saids FA Sample or something.
I select F010 and it shows active. Then i went to DSC section, right click the CAFD and coded it. When it starts writing the code, I got the ABS error
Instead of trying to fix it, I rather wait cause I have no idea I what was doing lol. I just want to fix the problem.
Or I should right click on DSC to code the whole section? Any help will be great. Shy
Right now lots of errors on dash. Thanks god car still drivable. I am so lost now.
Oh I am doing it wrong then. So when I get home tonight. First I connect the e-sys then read FA.You are supposed to use FA read from car, not FA Sample.
Read FA from car and VO Code DSC:
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Right-Click on DSC (the ECU itself not the underlying CAFD) => Select CODE.
Lite is fine for all coding.Oh I am doing it wrong then. So when I get home tonight. First I connect the e-sys then read FA.
do I need to use the full version of PSdZData or I can still use the Lite version to fix the problems?
Do you know if this e-sys program can fix my Chassis Stabilization Malfunction error ?
Cause I don't know if the Chassis Stabilization is under which module. Is there a cheat sheet I can find out what is for DME , DSC, EGS....etc.
Thanks Shawn
