1 - 20 of 24 Posts
I got new emblems, but I refuse to remove the existing ones before i know how to successfully install the new ones. anyone know the proper method to do this?
you take off the old ones by taking a pocket screwdriver and slowly taking them off you then pop out the two rubber grommets and then place the new ones in once this is done you pop in the new emblem and push down in the center to make sure it is all the way in ..... fairly simple
Freude am Fahren
Dealer showed me a trick. Use a piece is packing strapping about 18" long. Slip it under the edge of the roundel and pull up. It pops it off with no danger of scratching or marring the paint. I now keep a piece in my parts box for just that purpose.
Freude am Fahren
The strapping that you sometimes find around a cardboard package of a heavy item. Think about it. You know what I am talking about.
Faithful to the fest
Slip a business card under the emblem so u wont damage the paint then using a flat head screwdriver slowly pry the old emblem loose easy peasy
Thebizzy.com
Post f0cking pics already.
*Åþråh Cådåþråh*
+1 One of the safest ways to go about this issue.
Thebizzy.com
Packing straps
Ive used the packing straps, works ok. It just depends on how stuck the emblem is.
Premium Member
Dental floss.
Like a few of them together. Not just one. Put a few loops on each side (3&9 o'clock) and pull up.
mw
I tried the packing strap method... just broke the emblem...
Thebizzy.com
LMAO! ooops! I never liked that method anyway.
Premium Member
2 straps (or dental floss) each at 3 & 9 o'clock. Lift strait up at the same time.
mw
(slip a business card under the emblem so u wont damage the paint then using a flat head screwdriver slowly pry the old emblem loose easy peasy)
why -1 it worked for me :confused:
1 - 20 of 24 Posts
