  • BimmerFest Mobile App is now available on iOS & Android, Learn More
i have gliptone wax on my car . . .
841 Views 2 Replies 3 Participants Last post by  New Disguise
what if i use zaino on top of it. will that be ok? what do you think of gliptone polymer wax that uses dupont teflon?
lastly, when you guys use a PC type orbital is it really messy with stuff flying off everywhere. for example is it a good idea to wear some sort of apron.
thanks.
1 - 3 of 3 Posts
thanks.
Not sure about the first question...in regards to 2nd question, if you use it properly, very little product will come off the pad. You put just enough on do the the 2ft. by 2ft. section your working on, then apply the pad to the finish before turning it off, and turn it off while the pad is still applied after your finished.
Here's some videos to help you use a random orbital.:
http://autopia-carport.com/ProductTests/PC7424.htm
It is my beliefe that Zaino will not bond properly to the surface if there is another polymer wax present(especially if teflon based.) I'd give the car a good couple washes with Dawn to be safe.
1 - 3 of 3 Posts
