1 - 10 of 10 Posts
MY CAR KEEPS OVER HEATING..THE STEALERSHIP SAID IT IS PROBABLY THE HEAD GASKET...I ALREADY CHANGED THE THERMOSTAT..AND IT KEEPS HAPPENING...ANY HELP WITH LOCATING A NEW ENGINE IN NEW YORK WOULD BE GREAT..
THANKS:mad:
looking for a car
dude noway that cant be right maybe your water pump is bad or your car isnt cooling it down its highly unlikely that its the head gasket if it is then man that blows
dude, just because if your headgasket needs replacing does not meed you need a new engine, take hour car to a good indy shop in your area test can be done to verify if it is a headgasket failure, it probably isnt a water pump it it may be a bad fan clutch or your radiator may not be flowing well, and did you change the thermostat yourself and if you did , did you open the bleed screws when filling the cooling system
Sleeper
a 98 528i is not worth the engine swap, the value of the engine can possibly go beyond the value of the vehicle. its time to for for a 02 and up 525 or 530 if you like the economy and gas mileage of the i-6.
You Lick It, You Own It
you know, you can always do a S52 swap.. :D
1 - 10 of 10 Posts
