1 - 6 of 6 Posts
Hello all!
Could someone help me with getting a VO xml file for ista-p
R56 mini with vin
WMWMF335X9TU75382
THANK YOU!
Discussion Starter · #4 ·
Unfortunately it doesn't work. I am receiving a message that the vin is incorrect after importing it.
I might have bricked CAS module while initially trying to program it with ista-p. At the moment CAS, FRM and KOMBI are not coded with the car's vin. No lights on dash when key is inserted
Should I keep trying to get the right VO file and import it with ista-p or should I try to reanimate CAS with another measures?
Premium Member
The right VO File? If car VIN is WMWMF335X9TU75382, then it is right VO File. And if that is the case, at that point, I'd switch to ISTA+ and diagnose car.
1 - 6 of 6 Posts
