1 - 13 of 13 Posts
I like cookies.
Discussion Starter · #3 ·
VinceTopasBlau3 said:
They aren't too expensive for 16", are they?:dunno:
Damn...I can imagine my 18" set will cost a near $1k. :cry:
No, not too bad. $138 per tire. Still, lots more that I would like :eek:
A set of 18" Pilot Sports would be mad :yikes:
Rest in peace, Coach
nate328Ci said:
btw, anyone else ordered S-03s lately. My last set was supposed to be WR rated, but ZR was stamped on the tire.
I wonder what this will show up as....
YR.
edit: By the way, ZR is stamped on all tires rated over W. I think there are 3 different speed ratings, basically Z rated tires encompass all ratings over 149. W rated tires are rated over at 150-something so it'll get the ZR stamp. Y rated tires are rated at 180 something so again, it gets the ZR stamp. Then there's the truly Z rated tires that has no upper limit that can be tested on road going vehicles that simply gets the ZR stamp.
I'm pretty sure the 225/45/17 and the 225/40/18 S-03s are Y rated.
King of Rear Clunks
Often different sizes will have different speed ratings. Since these are all over 149MPH I doubt there's anything to worry about.
TXSunDvl
The HACK said:
All the tires Z rated and above, have the Z rating on the tire. The SO-3's are Y rated, but still show the Z on the tire. My OEM tires, Dunlap SP 2000E, were W rated but also had the Z on the tire. Apparently that is the max rating they physically put on the tires, even though the actual rating is higher.
I just put SO-3s on the rear.
King of Rear Clunks
There are 2 ways this is done.
A W-rated tire can be labeled as:
225/45WR17
225/45ZR17 91W
I believe
225/45R17 91W
is also valid.
The 91 is just an arbitrary load rating # I pulled out of my ass.
I like cookies.
Discussion Starter · #11 ·
225/45WR17
225/45ZR17 91W
I believe
225/45R17 91W
is also valid.
Right, they are 225/50ZR16 92W :thumbup:
I like cookies.
Discussion Starter · #13 ·
Re: natie:
blackdawg said:
you runnin' 16's or 17's on your car?
'thought it was the 17s on the 328s?
only problem i've ever had with s-03s (225/50/16s) is they have more grip than the blue pig (the wagon) has power. ha ha ha ha.
yea, 16s
A bit small looking :(
1 - 13 of 13 Posts
