The install but it was quite easy, but I did not make directions, do have a picture though.
The black tray insert in the armrest just pulls up, and out, extreamly easy.
I use the directions provided under a Thread in the X3 forum titled "center console CD player wires" by sonicf, to get to the drawings - Very helpful.
The only "special tool" I would say is a stubby Phillips Head srew driver.
I had to modify the Icelink Plus connector for it to work right (attached).
The hardest part is drilling the hole in the Black insert and feeding the wire through.
You have to make sure the hole is large enough for the connector to fit through.
I ended up putting two rubber grommets in to plug up the entire hole.
Because you cannot slip the grommnets over the connector you need to cut them and slip ober the cable. Very easy.
You do not need to be very handy - very easy.
Good luck, and let me know if you have any additional questions.
Hope this helps.
109.2 KB
83.2 KB
